fix 3rd brake light
Old Jul 18, 2005 | 02:41 PM
TaekOne's Avatar
TaekOne
pronounced tech
Default fix 3rd brake light
the bulb in my 7th gen coupe 3rd brake light went out a lil while ago. ive replaced taillight-bulbs before, and im sure this isnt a complicated issue but ive never had to deal w/ this. any help on where to get a replacement bulb and how to get to the light housing to fix it? thanks doods.
Old Jul 18, 2005 | 04:37 PM
oei28's Avatar
oei28
It should be fairly simple and it should still be a 7440 bulb like it is on my 6th gen. Just look for a couple screws directly under the brake light in the trunk then after you unscrew those, pop the tabs up with a flat screwdriver so you don't break them, then it should slide right off taking it off from the backseat.
Old Jul 18, 2005 | 05:22 PM
TaekOne's Avatar
TaekOne
pronounced tech
thanks, man. i'll take a look once it cools down. 95+ degrees is no thx.
