Radiator fan replacement question
Old Jul 6, 2005 | 06:58 AM
Spyfunkr's Avatar
Spyfunkr
Default Radiator fan replacement question
Hi guys. I just replaced my radiator fan motor. Its blowing towards the front of the car, when it comes on. Is this correct?
Thanks, Spy
Old Jul 6, 2005 | 07:10 AM
aztecicon's Avatar
aztecicon
i'm pretty sure it should be blowing toward the radiator .. thats how it cools
Old Jul 6, 2005 | 07:23 AM
Spyfunkr's Avatar
Spyfunkr
Well, yeah, but since the fan is behind the radiator, it would be pushing against the air coming in naturally. Also, the condensor fan blows backwards.
Thanks, Spy
Old Jul 6, 2005 | 07:39 AM
aztecicon's Avatar
aztecicon
i'm not an expert but i'm thinking that the fan only comes on when the car is not moving or reaches a certain temperature. is your A/C fan coming on .. i'm having a problem with mine .. it's making a weird noise when i turn my A/C on
Old Jul 6, 2005 | 07:49 AM
Spyfunkr's Avatar
Spyfunkr
Yeah, the other fan comes on occasionally even without A/C running. Haynes says the 2 are on totally different circuits. My radiator fan was making noise before it died. God forbid I should actually fix something when its warning me that its about to die!!!
-Spy
Old Jul 6, 2005 | 07:51 AM
Spyfunkr's Avatar
Spyfunkr
I posted on another forum, a guy over there said that its reversed -- air should be pulled through the radiator by the fan. Crap.
-Spy
Old Jul 6, 2005 | 12:24 PM
foot's Avatar
foot
The fan pulls the air through the radiator.
Old Jul 7, 2005 | 07:29 AM
JimBlake's Avatar
JimBlake
Even if you were to install a different fan out front of the radiator, you ALWAYS want it to blow the same as the natural direction of air coming thru while driving.
You can probably fix it by simply reversing the wires.
Old Jul 7, 2005 | 07:16 PM
foot's Avatar
foot
If you replaced JUST the motor, is it possible you put the fan blade on backwards?
