would those rims fit my car please help
Old Jun 13, 2005 | 02:06 PM
xbajbusx's Avatar
xbajbusx
Default would those rims fit my car please help
i got 2003 accord 4 dr would 2005 acura rl wheels work on my car please let me nkow would they fit ?
Factory wheels and tires from a 2005 Acura RL. The tires are Bridgestone Turanza. These wheels and tires will fit many makes and models of cars. They are 5 bolt wheels w/ the standard 4.5 inch bolt circle. To check if the bolt circle on your car is compatible with these wheels, use this link- http://www.rallyamerica.com/Measure.html be sure to use the 5 BOLT example in the diagram. These tires have zero miles on them. They are balanced and ready to install on your car. Tires and wheels are 17" (tire size is P235 45 R17).
Old Jun 13, 2005 | 06:09 PM
VTEC-Power's Avatar
VTEC-Power
should work
Old Jun 13, 2005 | 07:17 PM
jschmid's Avatar
jschmid
The bolt pattern should match up, but it would be nice to know the offset before you buy. The width of the tires are probably about the limit you could do on your car within reason.
Old Jun 15, 2005 | 03:21 PM
CB7.v2's Avatar
CB7.v2
on an acura forum, they said the new RLs have the bimmer pattern 5x120mm.
