need help on aftermarket headlight install
can't give you a walkthrough, but i know teh jist of it.
on our 5th gen accords its a pain to do the headlights.
1. start by removing ur bumper signal lights
2. remove upper grill (b/w the headlights)
3. remove teh bumper (i beleve there is a screw both front wheel wells, then a whole bunch of clips, you will recognize which clips once u take off the grille, they are push button clips)
4. once bumper is removed, remove the rebar
5. now your all set...just find the bolts for the headlights and ur done
