1987 Accord window motor removal
Old May 17, 2005 | 08:07 AM
ejluhn720's Avatar
ejluhn720
Default 1987 Accord window motor removal
I am trying to replace the front driver's window motor. The motor doesn't work and the window is up. The motor is mounted to the regulator with screws facing the inside of the door. I am attempting to remove the regulator to access the screws. I can't get the regualtor out since it won't fit through the opening in the door w/ the mechanism up. I have the glass out and all regulator screws removed. How can I get the window down and/or the motor off?
