01 Accord Coup door panel
Hi, I have a bad speaker in my drivers side door and I was curious if anyone has any detailed instructions on how I should properly remove the old speaker and install and new speaker. If you have pics, that would be awesome, if not, I'm sure i can follow a detailed explaination.
Thankz,
Thankz,
Helms or Haynes for the door panel removal instructions.
Speakers are straight-forward usually. You will need to detach them from the panel once you get to them and unplug them. Then, reverse it when installing the new.
screw paying for a guide.
http://handaaccessories.com/accord/accordwoodtrim2D.pdf
use this, it's the OEM woodgrain kit install directions. in it is a guide on how to remove the door panels.
