Check engine light........
Old Apr 24, 2005 | 05:52 AM
djdelirius's Avatar
djdelirius
Default Check engine light........
I've got a 99 Honda Accord EX V6 and the check engine light is on. Is there anyway to turn it off without taking it into the honda shop?
Old Apr 24, 2005 | 05:57 AM
Rice_Kit's Avatar
Rice_Kit
u can take out the bulb behind the dash. I think thats the only way. help me out =]
Old Apr 24, 2005 | 08:26 AM
kenton's Avatar
kenton
Change sig? Lose [quote]!
Pull the battery cables, wait a few minutes, put them back on.
Always worked for me
Old Apr 24, 2005 | 09:15 AM
FLAT_LINER's Avatar
FLAT_LINER
Ridin Dirty
take it to autozone i think they check and turn it off for free.....why dont u see what the problem is and fix it?
Old Apr 24, 2005 | 09:49 AM
skabone69's Avatar
skabone69
pull fuse #13 on the passanger side of the car. its the clock fuse. that will reset the ecu, its a lot easier and quicker than the other methods listed above.
Old Apr 24, 2005 | 01:10 PM
benjamin's Avatar
benjamin
Stuff and things.
Its worth mentioning that the light could be on as a result of something actually being wrong with the car. Its probably something simple and cheap like an O2 sensor, but it could be serious. Why do you want the light to be off? Are you trying to pass inspection without putting money into repairing the car?
Old Apr 25, 2005 | 08:03 AM
scanrps's Avatar
scanrps
Honda Parts Tech
Get the car checked out, only reason not to would be if you knew
you left the gas cap off and this trigged the light.
