2005 Accord Manual - Please Read
Old Apr 21, 2005 | 06:05 PM
Accord2.4's Avatar
Accord2.4
Default 2005 Accord Manual - Please Read
Rotation noise while moving slow, under 10 mph noise seems to come from trans area, seems to resonate through the axles to the wheels, noise, however does not occur under normal driving conditions, called tech line was told to poss swap know good components from other car to another, did swap tires/rims from another VEH. Noise still was heard POSS of Trans Gear Noise, which is common for a manual trans, to be heard at times upon low speed, Key off , Engine Off, car moving. CK'D w/Other new some VEH, Trans Noise was also Heard Inside of Trans, Also changed M/T Fluid...Noise seems to be common in Stickshift VEH 05, Accord.
This is the service write up they gave me. Not sure if it's a problem or not but if you have an 05, might want to check it out.
