Removing headunit
Old Apr 19, 2005 | 10:46 AM
nam9684's Avatar
nam9684
Default Removing headunit
I am a noob here, so easy on me please. My problem is im trying to remove my cd player so I can connect a FM modulator with my sirius radio. After removing the front panel, from what i can see there are 4 silver bolts that need to be remove, i have no problem removing the 2 top ones, but the 2 botom ones are so tight that i can't budge it. Is there a trick to removing these bolts? Or is there a way to get around it? Thanks in advance for the help. I own a '00 accord coupe V6 BTW.
Old Apr 19, 2005 | 10:52 AM
remove the control bezel (2 screws on the bottom, 1 behind the clock)
remove 4 screws that hold the radio in
the end.
if the screws won't budge, you can still get to the antenna plug from the back without removing the radio. there's only 2 things pluged into the back of the radio, a thick wireharness, and a pen shaped plug.
the black plug is the radio antenna.
Old Apr 19, 2005 | 12:29 PM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
You need to read the directions on your sirius, that's not how an fm modulator works. This could also lend some insight as to the reason why you can't undo a couple of philips head screws.
Old Apr 19, 2005 | 12:41 PM
if it's a hardwire fm mod kit, like the Delphi XM 1, then you'll need to run your power antenna wire though the kit, and from the kit, back into the radio.
Old Apr 19, 2005 | 12:52 PM
nam9684's Avatar
nam9684
Im doing hardwire, I was getting static from the wireless fm modulator, so im trying to install SATSWB to fix it.
Old Apr 19, 2005 | 01:06 PM
98CoupeV6's Avatar
98CoupeV6
Oh, didn't know you were doing hardwire. My bad. I have the SkyFi2 and my buddy's sirius has a wireless FM modulator like I do. Anyway, they're philips screws dude...get a correct size screwdriver and torque them good without stripping.
Old Apr 19, 2005 | 02:29 PM
nam9684's Avatar
nam9684
I've tried with all my strength, and still can't get it to budge. I had no problems with the top ones. Maybe im just weak. I guess i'll get a friend to try it.
Old Apr 19, 2005 | 03:15 PM
VPUPPY's Avatar
VPUPPY
your talking about the radio screws(the ones on the side of the radio that goes into the brackets?). if so, then those should be philips head screws can be removed by 8mm socket(the head is not round). if not, a trick would be to push in while you turn. another trick is to put a socket on the handle of the screwdriver and attach it to a ratchet. then push in and turn. hope this helps cuz its worked for me a few times. make sure your using the right sized screwdriver head too.
Old Apr 19, 2005 | 04:42 PM
scanrps's Avatar
scanrps
Honda Parts Tech
I had the static too with the wireless, so I went with the cheap/easy/lazy
way and just use the cassette adapter. It sounds fine, but a little messy
with the wires for power, and cassette adapters on the console.
