Clicking noise when I make turns
Old Apr 13, 2005 | 07:28 AM
atlantamike's Avatar
atlantamike
Default Clicking noise when I make turns
I have been experiencing a clicking/rattling noise in what seems to be the passenger-side wheel when I make left turns (recently started to occur when I make right turns). The strange thing is that it only happens when I am pressing the gas pedal during these left turns. I will be turning left and it start clicking/rattling and then I will let off the gas pedal and it completely stops, as if the problems depends on the gas pedal being pressed.
Is this the CV joints? Doesn’t seems like it because the clicking stops when I let off of the gas pedal. And when I put it in reverse and back up with a full turn motion, there is no clicking? Can anyone point me in the right direction? I’d appreciate any help. Thanks all.
Old Apr 13, 2005 | 07:44 AM
Illegal B16's Avatar
Illegal B16
New Zealand
check the boots on the axles to see if they're ripped, or maybe the wheel bearings.
Old Apr 13, 2005 | 07:46 AM
i'm guessing it's a busted CV joint.
Old Apr 13, 2005 | 08:52 AM
mayonaise's Avatar
mayonaise
it could still be the CV joint(s). maybe the torque applied to the joint when you're pressing the gas pedal is enough to cause the clicking, but just coasting (no gas pedal) isn't? just a guess..
the CV boot also doesn't have to be ripped or visibly damaged to be leaking. check for signs of leaking on and around the joint too, even if it looks alright. if you know a mechanic that'll put it on a lift for you, they'll probably be able to tell in a couple seconds.
Old Apr 13, 2005 | 12:06 PM
blacknight07601's Avatar
blacknight07601
Sounds like the CV joints. Normally happens when accelerating and turning at the same time.
Old Apr 13, 2005 | 06:34 PM
01ACCORD's Avatar
01ACCORD
How many miles on it? Classic CV joint wear. It will only get worse. If you have high mileage, you might as well replace both. You can get them with lifetime warranty on parts cheaper than the OEM. A bit of a bitch to install.
Old Apr 14, 2005 | 07:53 AM
atlantamike
Default Thanks to all who have posted
As everyone suggested it was the CV joints (and there is no way I was going to try to change them), I took my car to a mechanic and they confirmed that it was just that. So, it is getting repaired today and I appreciate all of the input that I received with this issue.
Old Apr 14, 2005 | 08:03 AM
:yay:
good to know that we're not full of crap ... 10% of the time. :chuckles:
any idea how much this is going to set you back?
Old May 11, 2005 | 04:32 AM
atlantamike
Default Cost me $271
This repair costed me $271 from a very reputable mechanic. Lifetime parts AND labor warranty. Thanks.
