Front brake shudder
Old Apr 11, 2005 | 04:37 PM
Henry Honda's Avatar
Henry Honda
Default Front brake shudder
My 1996 Accord EX with 84000 miles has started to shudder when brakes are applied at 60 mph or higher. Bought this car used 3 months ago with all repair paperwork included. Noticed new rotors were install at 74000 miles. Only 10 k on new rotors seems pretty bad. Any ideas ??
Old Apr 11, 2005 | 04:52 PM
the rotors are warped. you should get them resurfaced before it's too late.
Old Apr 12, 2005 | 12:01 PM
Henry Honda
Default Ok
I'll get it done, thanks.
Old Apr 12, 2005 | 12:54 PM
LouNC's Avatar
LouNC
Henry,
Not sure of your skills, you may have already checked this out. I would check to be sure you don't have a dragging caliper that may have caused rotor overheating and warpage.
I assume new brake pads were installed along with the rotors? If so, when the pistons were pushed back into the calipers, it's possible something may have happened that is now causing them to hang up and ride the rotor too tightly. Just a possibility worth investigating.
Lou
