90 Accord Power Door Lock Control Unit
Old Apr 6, 2005 | 06:31 PM
fac90's Avatar
fac90
Default 90 Accord Power Door Lock Control Unit
I had enough of my power door locks not working, so I took the door panel off and checked the power door lock control unit. After a few tests of the wire harness plug, the control unit is bad. Looking at the control unit pcb, it looks one solder joint of a relay is worn out. Could this be the cause, because the unit costs about $150.
Anyone else fixed theirs be resoldering the pcb?
The contol unit is for sure bad, because I got the all the door locks to lock and unlock by following the troubleshooting guide from the online manual at:
http://www.honda.co.uk/owner/AccordManual/index.html
Old Apr 13, 2005 | 08:47 PM
UCF Accord's Avatar
UCF Accord
Former Member
this happened to mine also. i resoldered the pin back on and it works perfectly
