Slight squeak coming from Belt/PS?
Old Apr 5, 2005 | 05:59 PM
jmg's Avatar
jmg
Default Slight squeak coming from Belt/PS?
I am having a very slight squeak from under the hood. I lifted the hood and it sounds like its coming from the pulley on the pump. Car steers fine, fluid is right and full. Belts look good. The squeak is slight but can be heard. Almost sounds like a squeaky belt.
ANy ideas? Just started about 4 days ago.
Old Apr 5, 2005 | 06:55 PM
VPUPPY's Avatar
VPUPPY
have you changed or removed the belt recently?
Old Apr 5, 2005 | 08:15 PM
H-Accord-22's Avatar
H-Accord-22
Duh
tighten it a lil. Touch the dense of the belt to make sure it's med tight, not too tight.
Old Apr 6, 2005 | 05:29 AM
JimBlake's Avatar
JimBlake
How old is the belt? The rubber can get old, hard, & slippery (breaking isn't the only way for a belt to go bad). Then you have to over-tighten it to stop the squeaking, & this hurts the pump bearings.
Old Apr 6, 2005 | 06:14 AM
jmg's Avatar
jmg
Havent touched it other than to feel the tenision. Belt was replaced at 60K, 2 years ago, now 90K.
Old Apr 6, 2005 | 10:22 AM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
Change the belt, takes 30 mins and costs $14.
Old Apr 6, 2005 | 12:31 PM
sibiryk's Avatar
sibiryk
To make sure that it is a belt just pour water (not too much) on it. If noise will stay than look for some thing else.
Old Apr 6, 2005 | 04:09 PM
jmg's Avatar
jmg
I put belt dressing on it and no luck. Not sure now. Sounds like its coming from the PS Pulley.
Old Apr 7, 2005 | 05:02 AM
sibiryk's Avatar
sibiryk
Take a belt of the PS and see if bearing is worn out.
Old Apr 7, 2005 | 01:40 PM
jmg's Avatar
jmg
I poured water on it today and it went quiet. I think its the belt. I was REALLY careful with the belt dressing and prolly didnt put enough on it.
