problems with DEPO JDM style corners
Old Mar 6, 2003 | 08:02 AM
aux's Avatar
aux
More Black on Black Crime
Originally posted by dave94ex
I still had to drill a different hole in the arm for the screw attachment. It still isn't perfect but unless you look closely, you can't tell.
:werd:. i need to do that myself. i just have some zipties holding them on h:
Old Mar 6, 2003 | 07:21 PM
VRGNCD5's Avatar
VRGNCD5
cause it's tight!
They Fit!
I basiclly made the cuts that re shown in that pic. I still had to drill a different hole in the arm for the screw attachment. It still isn't perfect but unless you look closely, you can't tell.
Sweet! Im gonna do mine saturday
Old Mar 8, 2003 | 10:58 AM
AcCO12D95's Avatar
AcCO12D95
I got some DEPO Black Housings for my 5th Gen, didn't have a problem with the corners at all. I just pressed against the corner with one hand then, screwed it tight so it would hold it flush...
The only ****ty part was the, drivers side corner started fogging up, ended up putting a tiny hole and blow drying it out then re-siliconed that sucker.
I would suggest you Silicon them before you put them on...to whoever has them out
Old Mar 8, 2003 | 11:14 AM
VRGNCD5's Avatar
VRGNCD5
cause it's tight!
u got the depo black housing corners mated to your oem headlights or did you get the depo headlights too?
Old Mar 8, 2003 | 10:43 PM
AcCO12D95's Avatar
AcCO12D95
I got the whole package (Headlight + Corners)....:thumbup:
Old Mar 9, 2003 | 04:33 AM
dave94ex's Avatar
dave94ex
moded but still slow
To quote myself...
Now I figured out how to make them fit perfectly!
You have to make the cuts as illustrated above. Then there is the headache of the arms that don't fit right. I drilled a new hole thru the arm and into the mounting bracket. That worked pretty well. At this point they fit pretty well but the drivers side still stuck out on the top a little bit and wasn't flush with the body...
Well, I figured it out - Its all about adjusting the Headlight mounting bracket. The 2 top bolts that you can easily get to with the hood popped open are adjustable front to back. If you install the corners as outlined in previous posts, you can fine tune your fitment by loosening these 2 bolts and adjusting the bracket until the corners are flush (top and bottom) with the body. You will have to re-aim your headlights but thats no bid deal.
Woo-Hoo! my JDM headlights now look like they came from the factory that way!
Old Mar 31, 2003 | 07:12 PM
AadosX's Avatar
AadosX
Do you have to do all of this stuff for knockoff JDM corners?
Old Mar 31, 2003 | 07:40 PM
usc's Avatar
usc
yes.
Old Mar 31, 2003 | 07:44 PM
AadosX's Avatar
AadosX
damnit.
wolfy47
Jun 15, 2009 02:10 PM
KjG8erZ8
Accord
15
Nov 12, 2003 08:42 AM
slpycd7
Accord
14
Sep 30, 2003 11:43 AM
s.cali alan
Jun 2, 2003 10:19 PM
mizturyous
Accord
11
Apr 25, 2003 09:52 AM
