Cel
Old Mar 30, 2005 | 04:59 PM
Tinker Bell's Avatar
Tinker Bell
mexikin who?
Default CEL :madfawk:
I put in a new clutch today and did a tune up now the dreaded CHECK ENGINE light has lit up. Any Idea on how to reset it?? on my generation 2 integra I would pull out a fuse under the hood for 10 seconds and it would reset.
Old Mar 30, 2005 | 06:03 PM
blacknight07601's Avatar
blacknight07601
Is the light constantly on or is it blinking?
IF it's solid you probably have to reset it like I did mine. Go to the fuse box under the hood. There's a 40amp fuse that says back up. Pull it and leave if out for 20 seconds then put it back and you should be set. You'll just have to reset your radio and clock.
If it's blinking you'll have to pull the code. You can go to autozone and they'll get the code for free.
Good Luck
Old Mar 30, 2005 | 06:57 PM
Cosmo M3's Avatar
Cosmo M3
Lurker
there's also the paper clip method where you just count how many time the CEL blinks and decipher it through a manual. Its somewhere in this forum, you might have to search.
Old Mar 30, 2005 | 07:16 PM
Tinker Bell
mexikin who?
its a solid light so Im about to go reset it now thanks :bigok:
*edit*
does the 40 amp fuse have 2 philips screws on each end that need to be removed?? because Ive been prying on them but it seems as though I have to remove these 2 screws first.
Old Mar 31, 2005 | 04:59 AM
blacknight07601
*edit*
No it doesn't (at least mine didn't) I believe the only fuse under the hood you have to unscrew is the 100amp main fuse. The 40 amp back up fuse should pull up pretty easily. I'mm see if I can get a pic of it later with my phone.
Old Mar 31, 2005 | 01:45 PM
Tinker Bell
mexikin who?
hey guys this is rayo's girlfriend and i just wanted some help here. i want to do the reseting since he's not here right now and i want to show him that girls can do this job also. So can i please get some help on how to reset the dumb check ingine light...
Old Mar 31, 2005 | 02:58 PM
blacknight07601
OK, here's a pic of the fuse you need to pull (in the fuse box under the hood) The fuse (marked with the yellow arrow) is for the power window motor. The fuse you need to pull is right in front of that one. It's marked with the blue arrow. On the fuse box cover, it will be labeled "back up". Pull it and leave it out for about 20 seconds.
Old Mar 31, 2005 | 04:27 PM
Tinker Bell
mexikin who?
I guess it might help adding the year and model of my car, its a 94 accord dx h:
I took out the only 2 40amp fuses under there and the bastard light still comes up :happysad:
Old Apr 1, 2005 | 04:53 AM
blacknight07601
Oh, sorry. The info I was giving was for a 6th gen
Old Apr 1, 2005 | 02:52 PM
honda guy's Avatar
honda guy
pull the 7.5 back-up fuse
