driver side signal won't blink
Old Mar 22, 2005 | 04:28 PM
2004blackbeauty's Avatar
2004blackbeauty
Default driver side signal won't blink
I have 2004 accord coupe v6-6speeds.
ok...I have aftermarket projector and halo headlights installed.
Everything worked except when i signal left; the signal light on the driver side won't blink.
the bulb is not fried because when I turn the light switch once and twice both the bulbs are lighting up including my halos and projector.
now it looks like that my driver side signal is not working.
I check the fuse box for the one for signal lights and I see NONE.
I have no idea why it won't blink...please HELP
Thanks
Old Mar 23, 2005 | 06:39 AM
diplomattik's Avatar
diplomattik
there should be one fuse for both of the signals, i think.. did u check yer manual?
Old Mar 23, 2005 | 09:44 AM
2004blackbeauty
ya I checked the manual and i couldn't find the fuse called signal of any kind.
If there is one for signals, would that make both sides stopped working?
It only happening to one side...driver side
Old Mar 24, 2005 | 09:17 PM
diplomattik
oh, sorry bout that.. i think they are separate.. but i'm not sure..
Old Mar 25, 2005 | 05:52 AM
blacknight07601's Avatar
blacknight07601
Sorry for a dumb question, but are you referring to the outside bulb won't blink when you signal or are you referring to the signal arrow in the car on the dashboard that won't flash?
Regardless, you can give them both a test. Just hit your hazzard button and check to make all the bulbs/arrows are flashing. If one bulbs isn't flashing then it's obvious that bulb is no good OR the wrong bulb is in there. If the bulbs are flashing but the internal arrow isn't, then the small bulb for that arrow is blown
