welding to fix exhaust leak
Old Mar 21, 2005 | 06:47 AM
hondadriver22's Avatar
hondadriver22
Default welding to fix exhaust leak
my cars got an exhaust leak around where the cat and downpipe meet. its been tightened as much as possible with air tools and the horrible sound remains while driving. is it possible to weld it so it is sealed? or any other suggestions will deffinitely help out.
Old Mar 21, 2005 | 06:56 AM
Illegal B16's Avatar
Illegal B16
New Zealand
your o-ring is there? Did you put the bolts/springs back in right? Is it the stock one or a aftermarket? What header? you sure there is no hole and it's coming from the connection?
Old Mar 21, 2005 | 10:40 AM
hondadriver22
im sure its from the connection, and it is aftermarket
hondadriver22
one of my friends mentioned something about braising it instead of welding
Old Mar 22, 2005 | 08:13 AM
hondadriver22
or is it possible that i need more gaskets? b/c the gap is deffinitely there.
Old Mar 22, 2005 | 11:35 AM
goodfella's Avatar
goodfella
i remember when the guy put on my new cat it had a leak...then he fixed it by welding
Old Mar 24, 2005 | 06:19 AM
hondadriver22
i was wondering, would making a homemade gasket help? (out of compressed aluminum foil paper)???
Old Mar 24, 2005 | 10:35 AM
hondadriver22
or would it melt??? i came up with this idea by myself so if it sounds retarded, give another way to seal it, w/o spending alot of money
Old Mar 24, 2005 | 02:12 PM
jschmid's Avatar
jschmid
h:
You have some interesting ideas.
I guess you could try some "liquid gasket" but I don't know how big of a gap you can fill with that.
Old Mar 24, 2005 | 02:37 PM
MrChad's Avatar
MrChad
THE RED 6th GEN Coupe
Perhaps the mating surface of the new cat flange is missing the groove to hold the Honda crush ring, I assume you used a new crush ring (gasket)?
Else welding should fix the leak.
