popping noise from front wheel
Old Mar 1, 2005 | 06:16 AM
streetfame01's Avatar
streetfame01
Default popping noise from front wheel
i have 01 accord for some reason when i drive there is a popping noise coming from the front driver's side wheel but if i push the brake it stops if you have any idea what it could be?
Old Mar 1, 2005 | 06:59 AM
2kAccord's Avatar
2kAccord
#010597
Warped rotor?
Old Mar 1, 2005 | 08:26 AM
JimBlake's Avatar
JimBlake
Loose brake caliper bracket bolts or slide bolts?
Brake pads fit too loose in the caliper bracket so they move around?
Loose ball joints?
Old Mar 3, 2005 | 08:01 AM
flytojungho's Avatar
flytojungho
is the bolts on the top of the suspension tight? you could hear popping noise if your suspension isn't on tight.. mine makes poping noise time to time when the weather is Freezing and this one time, my cai tubing was grinding against the body it self so whenever i start to gas, it made this dinging noise..
