Odd sound....hm?
Old Feb 15, 2005 | 10:03 AM
SecretChopSuey's Avatar
SecretChopSuey
Default Odd sound....hm?
Hey,
I have 01 accord Lx and recently while driving around usually on the freeway..I hear this metal rubbing metal sound from either my front or rear driver side. It's freaking annoying, so i just turn up the stereo..but it's been happening quite often now, and I'm thinking it might be something bad.
The odd thing is that once I press down on the brakes then it stops ! but once i release them the sound comes back. It's only when the car is in motion...
Just wondering if any of you guys know what might be the problem.
Thanks ! !
Old Feb 15, 2005 | 10:12 AM
SecretChopSuey
Oh yeah ! I have about 70% pad left if that has anything to do with anything
Old Feb 15, 2005 | 10:14 AM
teg92's Avatar
teg92
WHAT OK YEAH!
theres a metal plate behind the rotor maybe it got bent and its rubbing against something just a suggestion
Old Feb 15, 2005 | 11:50 AM
01ACCORD's Avatar
01ACCORD
I've also gotten a stone in behind the shield and it rubs. Put it up on the jack, and rotate the wheels by hand and see if you ca find the culprit.
I had to remove the wheel, and pull the caliper off to get all the crap out of mine.
While you are at it, make sure the calipers are free on the pins I grease mine with caliper grease. Don't use regular grease.
Old Feb 15, 2005 | 06:15 PM
Rice_Kit's Avatar
Rice_Kit
your brake is worn?
Old Feb 15, 2005 | 09:08 PM
SecretChopSuey
No my brakes are not worn,almost brand new. BUt yeah good idea, i'll jack it up this weekend and take a look Hopefully can find something...probably hit it with some brake cleaner while i'm at it.
Old Feb 16, 2005 | 04:59 AM
Rice_Kit's Avatar
Rice_Kit
my brake was good too but after I got into short distance race, ( 60-mph )
I was speeding then stepped on the brake....... ( not too hard../ didn't even make sssqquiikk noise.. )
next day, I heard metalic noise coming from my wheel, and I took it to the shop.
they told me my brake was bad.
at least I found out what was wrong. lesson learned.
Old Feb 16, 2005 | 07:23 PM
SecretChopSuey
Huh...why was your brakes bad? I mean why did the shop say they were bad..? Cause I do drive high speeds a lot cause of freeway and i'm always braking cause of traffic and such.
