F18b engine.
Old Feb 12, 2005 | 02:30 PM
johnpmcmullen's Avatar
johnpmcmullen
Default F18b engine.
Someone please tell me they have heard of this engine, its the little brother of the f22.im guessing maybe they only supplied it to euro spec accords.any info on turbo kits or if a turbo kit for an f22 engine will fit.please let me know of anything relevant.if ppl know of other performance parts please reply.
Old Feb 13, 2005 | 01:38 PM
Snoopy's Avatar
Snoopy
been there done that
nope never heard of it
Old Feb 13, 2005 | 04:50 PM
sherwood's Avatar
sherwood
I missed Sean
the lil brother to the f22 was the f20b and it was more of a second cousin than a brother, it was somewhere between h22 and f22
it's dohc so i dont think you'll have any luck with some of the stuff, but i dunno, that the f20b as i said.. never heard of the f18
Old Jan 21, 2009 | 03:53 AM
95ehurrob's Avatar
95ehurrob
del
Old May 16, 2009 | 01:07 AM
Muamer's Avatar
Muamer
Hi,
F18B is a SOHC and mods for it are going to cost you more... F block appears to be rare... However, to get a bit grunt and power, try with a good size, double cone air filter. Regular maintenance is a must, and use iridium plugs... Nice bore helps too... If you take out the originally supplied air filter box, you will get more than enough of space for doube cone. Make sure to create NICE FLOW of cold air. I used the secondary box, underneath. I punched a hole in it just large enough for 3' air duct. The inner pieces in this chamber i just cut of with a scraper. It was amission, but it works. Especially when cold outside. Use unleaded 95 or 98 instead of 91. Much better burning.
