Power brake fluid replacement
Old Feb 3, 2005 | 07:56 AM
jobrien's Avatar
jobrien
Default Power brake fluid replacement
'95 Accord EX
I need to replace my brake fluid. I plan to use OE fluid. I just need to know the best way to go about draining the fluid out for replacement.
Do I just go around to all four corners and bleed it all out of the lines starting at the driver's front side or what? Is there a drain to be used at the master cylinder as well?
Thanks in advance.
Old Feb 3, 2005 | 01:16 PM
honda guy's Avatar
honda guy
To get it all out you should bleed the brakes enough so all the old fluid is out
Old Feb 4, 2005 | 06:01 AM
JimBlake's Avatar
JimBlake
The MC reservoir is where it picks up more moisture, so suck that out with a turkey baster. (Then don't put it back in the kitchen...)
Fill with fresh fluid & bleed plenty of fluid thru each wheel, till it's fresh & clean.
