94 accord antenna problem
Old Feb 2, 2005 | 03:26 PM
smakdown's Avatar
smakdown
Default 94 accord antenna problem
The power antenna on my 94 accord lx seems to have froze or something. When i turn on the radio the motor still makes the same noise likes its working but the antenna is stuck up and won't move. I don't think its the motor....is there another piece in there somewhere that could have broke? How do i get to it?
Old Feb 2, 2005 | 05:46 PM
axemansean's Avatar
axemansean
Common problem, just use some grease.
Old Feb 2, 2005 | 05:54 PM
FLAT_LINER's Avatar
FLAT_LINER
Ridin Dirty
if you need another i have one ill sell you cheap
Old Feb 2, 2005 | 09:15 PM
magnanpi's Avatar
magnanpi
happened to me in the cold. just wate till its warmer. it will go away by itself
Old Feb 3, 2005 | 04:47 AM
JL95AccorD's Avatar
JL95AccorD
Is the antenna bent? Any slight enough bend will cause the antenna not to extend or go down properly. It doesn't mean necesarily mean that the problem is the motor or the teeth on the antenna mast. At least this was the problem that I had with my 95. In the longrun I just ended up extending the antenna all the way up, and then disconnecting the motor. Antenna makes a sound as if your car is farting when it gets stuck which is kinda anoying and embarrasing. Problem solved. i want to get satellite radio soon anyways, so once I get it I plan on putting the antenna down and maybe even just shaving it off.
Old Feb 3, 2005 | 11:12 AM
as_merrill's Avatar
as_merrill
aka FlamedAccord
There is a guy looking for one in another thread, can you help him out???
https://www.honda-acura.net/forums/s...d.php?t=174993
