help- 92 accord ABS code
Old Jan 31, 2005 | 06:18 PM
bigt61's Avatar
bigt61
Default help- 92 accord ABS code
my wifes 92 accord EX has the ABS light staying on after the car has been in motion.
I jumped the service connector with a paperclip. the ABS light flashes code 1. how do i fix this?
Old Feb 1, 2005 | 06:43 AM
JimBlake's Avatar
JimBlake
In my '95 Integra that's 'ABS pump motor over-run'. (Good chance yours has the same ABS system.)
That can be caused by air in the ABS. Fresh brake fluid & bleed the air out would be the first thing to do. Then you can start worrying about pressure sensors or bad pumps.
Old Feb 2, 2005 | 07:55 AM
bigt61's Avatar
bigt61
anybody have a more in depth answer? hopefully from an accord owner?
Old Feb 3, 2005 | 05:49 PM
bigt61's Avatar
bigt61
bumpity bump bump... anybody?
Old Feb 4, 2005 | 06:59 AM
CJITTY's Avatar
CJITTY
Dude has a 95 and 03 Accord??? Wouldn't that make him an owner? I have a 92 Accord EX and luckily no ABS light, but I got majore rotor warping issues happening every 2-3 months.
Old Feb 4, 2005 | 07:03 AM
sherwood's Avatar
sherwood
I missed Sean
:thinking: but he totally said that was the code for his teg's ABS
Old Feb 4, 2005 | 08:22 AM
JimBlake's Avatar
JimBlake
My '95 is an Integra. Beginning in '98 Honda changed the ABS system, I think across all models. So my '98 Accord doesn't count. The '95 Accord ABS system hardware has more in common with a '95 Integra than it does with a '98 Accord. I figured they used the same list of error codes, but I'm not absolutely sure.
Old Feb 4, 2005 | 08:44 AM
sherwood's Avatar
sherwood
I missed Sean
maybe, i know that 5th gens like to spit out random ABS codes when the system is working fine... not sure about 4th gens tho
Old Feb 5, 2005 | 12:08 PM
bigt61's Avatar
bigt61
Integra codes and accord codes are much different, I already know that. The dealership told me so. They said they wanted 90 bucks to put it on a machine and test it out to see what the code was. I'm thinking i'm gonna find a right answer and fix it myself.
Old Feb 7, 2005 | 04:29 AM
JimBlake's Avatar
JimBlake
Bleeding the ABS fluid to remove air bubbles is a straightforward, easy thing to try. I wouldn't want to tell you to start testing/cutting/splicing wires without having the repair book for the proper model & year.
Go to www.helminc.com & buy a repair manual. So they want $90 to read the code, but this book is only about $70. Pays for itself right there. Besides, you've ALREADY read the code. All the codes are listed in that book, with very detailed procedures for finding what's broke based on which code you read. (Remember, the code doesn't say exactly what's broke, it only narrows down the search.)
Or... sit & wait for someone with a '92 Accord Helm book to post... (I'd be curious to know whether the codes are really so different.)
