What size rims for a 98 accord 4 door.
If you want the right size rims and tire combo, use the following tire calc. It will help you decided what size is best so the car can run as if it were running on stock wheels.
http://www.miata.net/garage/tirecalc.html
for example if you your car OEM's are 195/65/15 then 225/45/17 is the best so the speedometer stays balanced, you will be doing 60mph when the speedo reads 60mph, other combos will make your speedo read 60mph but u might be going slower or faster than that.
I have decided that am going to drop it. And get some 18's . What size rim ( 18/8.5/5 x112 ect..) and tire would fit good on a 98 4 door accord? Am a noob to this shit i don't know shit about rims etc..
think about rims if you still have money after the suspension work:
Drop: Springs & Shocks or full coilover
camber kit: SPC or ingalls (I like my SPC)
Sway bar: Suspension Techniques or any others.
These alone can be costly
Btw, afterward, get some 18s. They look right on 6th Gen.
btw, Jschmid, I keep envy you everything I look at your car. (same goes to Chad as well.) Are those the Royal steel grey? Do you have some close up pics. I'm thinking of getting a set of 17s for as my daily/winter (or 16 - still can't decide)
