Brake Noise
Old Jan 29, 2005 | 05:17 PM
ohhonda98's Avatar
ohhonda98
Default Brake Noise
I just swapped out my brakes and rotors for a set of cross-drilled rotors and MEAN GREEN pads. Now I hear this strange noise when I drive at low speeds.... WTF??? Do i need to replace the shims or what? Please advise...
Old Jan 29, 2005 | 07:06 PM
PissedPanther's Avatar
PissedPanther
sounds like what?
Old Jan 29, 2005 | 09:25 PM
wedley2's Avatar
wedley2
bboy Wesley West
are they rubbing?
Old Jan 29, 2005 | 11:43 PM
strykernyc's Avatar
strykernyc
GREEN PADS are CHEAP stuff. switch pads go to autozone get the best pad they have $40 lifetime warranty free replacement if any noise
Old Jan 30, 2005 | 04:32 AM
ohhonda98's Avatar
ohhonda98
The noise sounds as if the pads are rubbing.
Old Jan 30, 2005 | 07:28 AM
Mr Hyde's Avatar
Mr Hyde
Accord Forum Moderator
If the rotors have any protective/decorative coating on them, you could get some scraping noises until that coating wears off.
Just call me.............Mr Hyde
03 Topaz Blue 540i M-Sport
The TL-S / The 540i
Old Jan 30, 2005 | 07:31 AM
FLAT_LINER's Avatar
FLAT_LINER
Ridin Dirty
^ yeah....you should spray them with carb cleaner or something to eat that stuff off....that could be your problem
Old Feb 2, 2005 | 05:14 AM
JL95AccorD's Avatar
JL95AccorD
Did the ends of those pads need to be grinded down? Not all pads come with the ends grinded, and that would cause the pad to rub with the rotor.Dirve around and "abuse" the breaks a little, try driving with brakes pressed down also to help burn off anything on the pads or wear down whatever might be rubbing. Don't drive like that too long without letting the discs cool down though. You don't want to warp or carck them. Did they have some "glue" on the back to hold them against the piston? If not then they would be loose and be leaning against the rotor and rubbing on it. It definately sounds like rubbing because it's only when you are going slow. If they are really cheap pads and they have been on for a while now it could also just be break dust that is acumulating and rubbing. In that case some strong pressure with a hose could get in there and wash it out as well as some good break dust cleaner found in rim cleaners and such.
