Sub problem in 98
I didn't know whether to put this is the accord forum or the Audio forum, but i think that it may be a specific problem in the 98-02 accords.
When i first got my subs ( 2 12's) in my 98 accord, 4 door, everything was fine. Now after about i month since they were put in, the subs are sliding towards the back of the car everytime i go somewhere. Before, they would slide 2-5 inches max, even after some hard cornering. It wouldn't be that big of a deal if the power, rem, and ground didn't come disconnected everytime they slide. Does anyone else have this problem or a solution to it? Is the design of the trunk the problem?
Why don't you get some clips to hold the sub box in place, I think most folks do this, I know I usually do?
www.partsexpress.com
the carpet is no longer able to 'grab' the boxes as they did before. i bet if you run your hand on the surface, your hand will not meet that much resistance in the middle as the outer edges of the trunk mat. you need to secure the box as said above.
