Another CEL Light post.?
Old Jan 8, 2005 | 04:10 PM
Sheridon01EX's Avatar
Sheridon01EX
Default Another CEL Light post.?
Was driving home from store CEL light just came on.. ... when i got home I tried jumpering ports 8 and 13 to get the CEL code but the light just came on and stayed on again without blinking or anything . Didn't seem to have any problems when i was driving it. i have a 2001 4cyl ULEV manual. what you guys think? Does the light come on if its time for normal service... it has about 40800 miles on it....
Old Jan 8, 2005 | 04:58 PM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
After you jump the connector you have to turn your key off then to the II position.
http://mywebpages.comcast.net/jweller1/check_eng.html
Old Jan 8, 2005 | 05:02 PM
Sheridon01EX
I tried to jumper it in the off position and then turned it to the on position and the light just stayed on... have to jumper pins 8 and 13 right?
Old Jan 8, 2005 | 05:23 PM
98CoupeV6's Avatar
98CoupeV6
Look at the damn link. Do what it says. Make sure the paper clip is making contact with the metal on both ends.
Old Jan 8, 2005 | 08:06 PM
RKV's Avatar
RKV
ur probably putting it in the wrong positions, depending what diagram you look at it, could be upside down or right side up haha
Old Jan 8, 2005 | 08:23 PM
Sheridon01EX
Ok, wire i was using wasn't makin good contact.. CEL gave me a code of 61....Primary heated O2 sensor....
