Help with radio code
Old Dec 10, 2004 | 01:24 AM
BONE's Avatar
BONE
I had a similar situation with my car if you make a mistake putting in the radio code it will give you 10 tries to correct it if not then you have to let the car sit for a couple of hours to clear the error then you can put the code in again.
Old Dec 12, 2004 | 07:37 AM
AccordEX's Avatar
AccordEX
i heard you can find the code in some of the following places: left hand side of ur glove box on the outside, under the so called coin tray on the left hand side of ur steering wheel, under the fuse box lid on the inside or under the trunk lid. best idea like most of the guys have mentioned hear is take the radio out and just call the dealer for a code.
Old Dec 14, 2004 | 04:03 PM
shondaaccordex's Avatar
shondaaccordex
This may be a little late. But I can answer the problem for you. The only way to ge the code, unless you find the code identification car that comes with the car, is to get the serial number off the oem radio. The only way to do this is to remove the radio. I can tell you how to do that too if you wish. The dealership can only retrieve the code from the serial number. Not the VIN number or anyhting else. If you need more help, just contact me.
Old Dec 14, 2004 | 04:43 PM
HatchVX's Avatar
HatchVX
Driving a Turbo 2L Terror
I can get u the code if u get my the serial number. I work at a honda dealership.
