95 Accord LX Power Window Dilema
Old Dec 6, 2004 | 03:31 PM
slaint's Avatar
slaint
Default 95 Accord LX Power Window Dilema
The other day I had my driver's window down and went to put it up and it did nothing. The only thing it would do was go down further if promted to. All the other windows worked fine. I went to a salvage yard today and found a master switch off a Civic that fits and seemed to work. The drivers window now works in both directions and the left rear window works fine, but neither of the passenger side windows work at all, wether its from the master switch or the individual switches. The lock system is off so they should work. Is there a fuse that operates the right windows separately that may have blown??? Is is the Civic switch? Did I guess correctly in thinking it was the switch to begin with??? Any help would be great. Thanks.
Old Dec 7, 2004 | 09:45 AM
apexivtecaccord's Avatar
apexivtecaccord
ITZJDM
get the correct switch and check the wiring in the door jam
Old Dec 7, 2004 | 09:52 AM
sherwood's Avatar
sherwood
I missed Sean
its the master switch gone bad, happens to mine all the time, all i had to do is take the switch out and then flip it aorund for the time being,... still looking for a new switch
Old Dec 8, 2004 | 08:55 AM
magnanpi's Avatar
magnanpi
happens to me sometimes it stops going down, and sometimes going up. the other day i put it down and then it wouldnt go back up. it took a while but eventually it made it up. it took about 5 times. it stopped halfway up and would only go down. but it worked.
power windows in all honda acoords = shitty.... period
Old Dec 8, 2004 | 05:21 PM
sherwood's Avatar
sherwood
I missed Sean
its seriously just the contact, reverse the switch, you can always do the half press (sorta push it in the middle) to make ti work, but that iwll damge the switch faster than reversing it altogether.
