Accord LX 91 will not start
Old Nov 27, 2004 | 11:17 AM
jaymorrissey's Avatar
jaymorrissey
Default Accord LX 91 will not start
Please help!!!
Car turns over but no spark to plugs.
Have replaced coil.
What is Next?
Thanks for your help
Old Nov 27, 2004 | 05:33 PM
hondatech's Avatar
hondatech
Honda tech/eprom hackr
I would check the igniter next. It's usually one or the other on these accords (coil or igniter). I have seen rodents chew up the harness that goes into the dist. assembly and cause a car to not start but it's not as common as a bad coil or igniter. I usually check for ref. voltage to the coil on the primary circuit and to the igniter, the igniter should pulse on a test light when you crank the car over.
Old Nov 30, 2004 | 10:27 AM
hype8912's Avatar
hype8912
Dr. Klaw
Will it start sometimes or just not at all?
Old Nov 30, 2004 | 11:09 AM
jaymorrissey
I have replaced both the ignitor and coil and still no start.
The car does not start, all the time, not occassionally.
Old Nov 30, 2004 | 11:46 AM
seansosmooth05's Avatar
seansosmooth05
it coluld be ur destibuter or altanater (if i spelled that right) i got my altanater a lil wet once and it wouldnt start untill i compleatly cleand it out with WD40, and my old car the distributer went out and it did the same thing, crank but no start
