Brake problems on 2003 accord lx 4 dr wobbles when brake
ok here is a deal 2003 accord i keep having problems with the rotors first my accord went to a dealer on brake pads recall because the stering wheels was wobbeling when braking ,few weeks later after they cut the rotors sam e think happend i had to cut the rotors again ,they told me that the material is cheap ,again i'm starting to have wabbeling when braking any suggestion should i get diffrent rotors anybody ,help
uhhh......yeah...If you had problems with the same Brake rotors twice, then your better off buying some Brembo rotors or something.
Even on my 02 accord the stock brake rotors sucked. So I spent the 300. something bucks and bought myself the brembo cross drilled slotted rotors..OEM size of course.
I havent had any problems with those rotors and they are so much better than OEM in every aspect.
You could also just get Brembo blank (non drilled, slotted) that should give you a bit more life out of them. I have Brembo blanks and OEM pads on my 99. Although my stock OEM rotors did last 70K miles.
Originally Posted by xbajbusx
cool where i can get them from
