oil for 100K+
Old Nov 5, 2004 | 09:09 AM
uclaccord's Avatar
uclaccord
Default oil for 100K+
is high mileage oil really worth it...the claims are that high mileage oil makes the seals tighter/better and other stuff i forgot...but jw cuz i'm due for an oil change
Old Nov 5, 2004 | 09:14 AM
skabone69's Avatar
skabone69
it makes the engine run smoother. you could either get the high milage oil, or engine restore. they both do the same thing. I used engine restore on my last oil change and the car has been running a lot smoother because of it.
Old Nov 5, 2004 | 09:45 AM
uclaccord's Avatar
uclaccord
what's engine restore
Old Nov 5, 2004 | 11:13 AM
DarkSideAccord's Avatar
DarkSideAccord
Chidori-chan :love:
use thicker grade oil...it'll give ya more protection... it's ok to go for synthetic, but i'd stick to mineral
Old Nov 6, 2004 | 10:45 AM
FLAT_LINER's Avatar
FLAT_LINER
Ridin Dirty
i use rotella in my accord.... 244,xxx and still kickin it
Old Nov 6, 2004 | 04:28 PM
TenaciousTires's Avatar
TenaciousTires
Registered Luser
Using the high-mileage oil isn't going to hurt anything, but at only 100k, I doubt it's really necessary...unless the engine is consuming oil or has lost compression, in which the high-mileage oil would provide better protection. Otherwise, it's unecessary. I'd stick with regular 5w30 or 10w30 oil. Switching to a synthetic oil this late in the game might cause premature leaks.
Old Nov 6, 2004 | 09:37 PM
REbornHONDAneer's Avatar
REbornHONDAneer
Honda Biased
Thicker oil means more resistance in the engine, meaning slightly less gas mileage(not much of a reason). No where in the manual(more of a reason) does it say to switch the oil at a certain mileage so I don't. I still use 5w-30 in my 93 civic with 165,*** miles on it. I'll keep using that grade oil.
Old Nov 7, 2004 | 12:16 PM
iobidder's Avatar
iobidder
Registered Abuser
Mobil 1 Synthetic 5w30
