Engine advice
Old Nov 2, 2004 | 07:43 PM
Apachejct's Avatar
Apachejct
Default Engine advice
Due to cracking my block when the oil pump went in my 94 Accord, I'm considering buying an H22 motor with an LSD tranny. The engine comes with:
•Motor(90-97)
•Automatic Transmission(LSD)
•Engine Wiring Harness(Complete)
•All required Cables
•ECU ODB - 1 P13
•Distributor
•Throttle Body
•Injectors
•Complete Intake Manifold
•Alternator
•A/C
•Power Steering Pump
•All Brackets and Sensors
my question is what else will I need to get to complete this swap. Is there anything on my car that is interchangeable? I know that there are how-to's for swapping the prelude motor into my accord. But as a newbie in this field I figured I'd ask the pro's.
Old Nov 2, 2004 | 11:50 PM
bonestock's Avatar
bonestock
use accord axles.
you need to wire up the vtec soleniod, vtec pressure switch, knock sensor
and secondary intake soleniod
if you want to the keep ac you hafta take the bracket off the F22 and put it on the H22 and use the accord compressor
you need a 92-96 prelude timing belt side mount and it has to be shaved down a bit. the rest use the accord mounts.
you will need to chop part of your exhaust cuz it will be too long.
thats all that i can think of off the top of my head.
