Strange 'buzzing' sound
Old Oct 20, 2004 | 10:41 PM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
Originally Posted by 95Mugen
do you know how much for autozone to check the code?
They'll perform any "check" for free and usually get fairly pissy if you say "thanks a lot" and get in your car afterwards, but who cares.
On the 6th gens though you can pull your own codes using a paperclip and a couple of Helms manuals, so I haven't been down there in awhile.
Old Oct 22, 2004 | 04:54 PM
JD911's Avatar
JD911
Banned
Originally Posted by accordvtec77
The ABS unit on a 5th gen Accord sits right behind the driver's headlight assembly. There's a rubber plug on the top about the size of a quarter (probably gray in color). that's where you fill the reservoir. Keep in mind there is a bulletin on this generation Accord, where the ABS unit leaks, and that's why the reservoir keeps going dry. It involves loosening and retightening some of the plugs on the ABS unit. I don't recommend you try and do this yourself, because it's a bitch. I've done a few at work...NOT easy.
If it is leaking do you know where it would be leaking from?? is it just the resevoir? if so would it not be easier to just replace that resevoir?? its just a small plastic thing it can't be that expensive. or can it.....?
Old Oct 22, 2004 | 05:48 PM
accordvtec77's Avatar
accordvtec77
There is a bulletin on this leaking problem. It's not the reservoir. There are certain "plugs" on the body of the ABS unit that need to be loosened and retightened. There is roughly 10 of these plugs on the unit, and the bulletin tells you exactly which 6 need to be retorqued. The brake fluid will leak out of those exact 6 plugs.
Old Oct 22, 2004 | 08:28 PM
JD911's Avatar
JD911
Banned
hmmmm ok, that brings up another question. Does anyone know where i can find a list of honda TSB's??? I tried alldata.com but they charge to gain access to the bulletins. Does anyone know someone that i can read them for free?
Old Oct 24, 2004 | 07:38 AM
Big Chaze's Avatar
Big Chaze
Mr Clutch
http://www.bba-reman.com/hondaalb2computer.htm
http://www.dhost.info/accordinfo/
