Speakers...HELP ME!!
Old Oct 19, 2004 | 09:24 AM
before hacking off the stock harness ... why not get a speaker adapter from circuit city? they're only $8 a pair.
Old Oct 19, 2004 | 09:31 AM
dhor6x9's Avatar
dhor6x9
smokaholic
ok, where im at is, i have hacked off the harnesses and now have two wires coming from the harness place, and 2 wires from the speakers, i am going to try to go take a picture to give some perspective of it, but i just need to know where to go from there, im very frustrated, ive been lying down in this trunk in my garage for over an hour
Old Oct 19, 2004 | 09:36 AM
strychnine's Avatar
strychnine
i am legend
damn, too late. don't throw out the plug you cut off in case you decide to sell the car and don't want to leave your new speakers in it. it's better to just buy some quick connects and put them on the end of the wires.
Old Oct 19, 2004 | 09:37 AM
strychnine's Avatar
strychnine
i am legend
give me a sec and i'll tell you what goes where
Old Oct 19, 2004 | 09:39 AM
dhor6x9's Avatar
dhor6x9
smokaholic
where do i get the quick conects?
Old Oct 19, 2004 | 09:52 AM
strychnine's Avatar
strychnine
i am legend
you should have two wires on each side where you cut the plugs off. on the right you should have a brown wire with a white stripe and a red wire with a yellow stripe, one the left you should have a grey wire with a white stripe and a blue wire with a yellow stripe. the wires with the yellow stripes are your positives, hook them to the speaker wires without a stripe. hook the remaining wires to the wires with a stripe.
sorry if thats confusing, but you should have the following:
two wires coming from your right speaker, one with a stripe one without, the one without a stripe should be hooked to the red/yellow wire, the wire with a stripe should be hooked to the brown/white wire.
on the left you should have the same except the blue/yellow wire should be hooked to the one without a stripe, and the wire with a stripe should be hooked to the grey/white wire. make sure you do something with them, tape them or something until you can get some connectors
Old Oct 19, 2004 | 09:53 AM
dhor6x9's Avatar
dhor6x9
smokaholic
ok, do i cut some of the rubber aroun the wire off, and then twist the ends to one another?
just look for the 2 metal tabs and attach the stripped wire to that.
File Type: jpg
Old Oct 19, 2004 | 09:54 AM
strychnine's Avatar
strychnine
i am legend
you've already cut the harness so you don't need them now, but you can get them from any parts place, walmart, radio shack if you decide to replace your fronts.
look like this
Old Oct 19, 2004 | 09:56 AM
strychnine's Avatar
strychnine
i am legend
true thatd probably be simpler, but i didnt know how far back he cut the wires. i was assuming he used the wires that came with the speakers
