Abs motor pump?
Old Sep 30, 2004 | 07:42 PM
accord95ex's Avatar
accord95ex
Default Abs motor pump?
My abs light came on today. When I started the car the abs light doesn't show up yet. Then after maybe 7 sec. or more it turn on and make a little click. I have tested it out by plugin the paper clip and the code show that it's a code 1. Someting wrong with the motor pump over-run? What you mean by that and how do I fix it? I'm not sure if that is the code. I put the paper click in the 2 wires. Turn on the key. The abs light flash once, about 3 seconds later flash once again, and another 3 seconds flash once more. Then it stop. So therefore that is a code 1 right? Thanks I hope someone will help me out.
(94-97) ABS DTCs...
1 - ABS pump motor over-run
1 2 ABS pump motor
1 3 high pressure leakage
1 4 pressure switch
1 8 high pressure system
2 1 parking brake
3 1 pulser RF
3 2 pulser LF
3 4 pulser RR
3 8 pulser LR
3 12 different diameter tires
4 1 wheel sensor RF
4 2 wheel sensor LF
4 4 wheel sensor RR
4 8 wheel sensor LR
5 - rear wheel lock - R/L
5 4 rear wheel lock - R
5 8 rear wheel lock - L
6 - fail-safe relay - F/R
6 1 fail-safe relay - F
6 4 fail-safe relay - R
7 1 solenoid - RF
7 2 solenoid - LF
7 4 solenoid - R
8 1 ABS function
8 2 CPU comparison
8 4 IC self-check
