LED replacement bulbs
Old Aug 14, 2002 | 05:54 PM
fly5150's Avatar
fly5150
Default LED replacement bulbs
Ok.... so I was lookin garound on the net at replacement bulbs, and i see that they now have 194 bulbs in LED and 1157 and all the other types. I am a fan of Led's, has anyone had good experience with them, and who is a good manufacture of them, i dont want to waste my money on something that will burn out in a few months. Plus I want to try and not have the crazy fast blinking that usually happens with the LED lights.
Thanks
Old Aug 14, 2002 | 06:01 PM
VRGNCD5's Avatar
VRGNCD5
cause it's tight!
Default Re: LED replacement bulbs
Thanks
my first experience w/led lights wasn't too good. I got the hyper blinkers(which isn't cool on an otherwise stock car) and they also drained my battery. I couldn't tell you how or why but after putting in my led's, my battery was dead within a week. After putting back the regular bulbs, no more hyper blinkers and battery was fine.
Old Aug 14, 2002 | 06:11 PM
SumAccordGuy94's Avatar
SumAccordGuy94
Older Honda Fanatic
the 194 corner bulbs are not a problem if changed...
If you put 1157's in the brake lights, your "brake light" idiot light will come on.
You can put them in your turn signals, but you need a variable load flasher to make them flash at the proper speed.
They bright/dim "filaments" tend to not be as noticable as with a regular incandescent bulb... but LED's are rated to last about 100,000 hours... which basically means they should out-last your car.
