1994 Accord Wrecked... Need suspension help
Ok, I just bought a 1994 Honda Accord EX 4dr and it has been wrecked pretty good... The rear passenger tire/rim, is shoved back into the fender opening and cocked off at an angle. What I need to know is, what is the name of all the parts of the suspension that hold the wheel in the proper place?? There is a long wide bar going from the frame in front of the wheel, to the hub assembly that looks bent... There is a thin bar on the back of the assembly that goes from the hub to the body.... it is aligned from side to side. It is also bent. And there is an upper ball joint looking thing, it also may be bent... Is there anywhere I could find a breakdown picture of this assembly? Or, any of you know these parts names? Any help would be greatly appreciated!! Thank you all!
