Car won't start :-(
Old Sep 7, 2004 | 10:01 PM
rdiggidy's Avatar
rdiggidy
Default Car won't start :-(
Today a radiator hose broke on my car. The car started to heat up, I quickly pulled it into a gas station, let it cool down a bit and then put some more water in it. It made it the 20 or so miles back to my house without heating up again.
When I got home I pulled the hose off, got a new one and put it on. There was quite a bit of water/anti freeze that had sprayed all over from the leaky hose, so I let the car dry out a bit and then tried to start it up. No go.
The car turns over, and seems to have plenty of juice, it just won't start up. The car's battery is strong (just tested), alternator is good (just replaced), checked the plugs and wires (both replaced recently and seem good).
I pulled a couple spark plugs and couldn't get a spark, so then I was thinking the distributor. I checked all the connections on the distributor and they looked good (no liquid), but I went ahead and took the cap of and blew everything out with compressed air.
I'm wondering if the distributor just happened to go out, unrelated to the radiator hose problem/water. The car has 215,000 miles on it, so I guess it's possible that it was just a bad day for my Honda.
I'm going to let the car dry out over night and hopefully it will start up in the morning and get me to work, but I'm thinking it probably won't....so what are your suggestions for where I should go from here/what I should test next? I'm a pretty novice mechanic so if it's complex help me to understand.
REALLY appreciate your time!!
Ryan
Old Sep 8, 2004 | 04:43 AM
strychnine's Avatar
strychnine
i am legend
is the cam spinning?
