ignition switch problem
Old Aug 6, 2004 | 09:12 PM
Momobile's Avatar
Momobile
Mom's shade tree mechanic
Default ignition switch problem
The car will not run unless I hold the key in an exact spot (just slightly back without the starter engaged). If I let go of the key the car will die. I was told that the mechanical part (key) of the ignition needs to be replaced (not the electrical switch part). He said there is a spring that goes bad and the key doesn't hold in place and the car won't run. Can anyone confirm this?
Old Aug 8, 2004 | 07:51 PM
Momobile's Avatar
Momobile
It was the electrical part of the ignition switch. Cost $86 for the part!!!! but it's fixed now.
Old Aug 10, 2004 | 10:02 AM
JimBlake's Avatar
JimBlake
Seems kinda common, either the lock cylinder or the electrical part. Got a big heavy keychain?? That seems to make the lock cylinder screw up faster.
Old Aug 10, 2004 | 12:18 PM
Wes's Avatar
Wes
z...Z...Z
I had the same problem.
Old Aug 10, 2004 | 04:02 PM
Momobile's Avatar
Momobile
The dealer said this is a very common problem and that the later models had a recall.
