valve cover
How about adding some locking washers to the top of the valve where the bolts go? This would keep pressure on them, and hopefully stop them from coming loose. Just an idea from a simple point of view.
Probably, like most accords of that age, your rear hydraulic engine mount is shot (like mine) thus causing your engine to vibrate and pitch badly when you change gears. Plus if my experience with subwoofers is any indication, Shaking = loose bolts!
Ok this thread is full of stupid responses.
Shams idea of lock washers and Nemos gasket thought are the two most logical....the rest are plain moronic.
Like Nemo said check the gasket around the valve cover and make sure it is located correctly in the slot. Also while it is off check the rubber grommets located at each of the valve cover bolts, if they wear out they can cause play which ill allow the cover to loosen up easily. If neither of those is the case then try the lock washers that Sham suggested....this is kind of a last effort though
