6th GEN ELECTRICAL QUESTION HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Jun 23, 2004 | 07:28 PM
ODUB's Avatar
ODUB
Banned
Default 6th GEN ELECTRICAL QUESTION HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
if you accidentally connected the negative battery cable to the positive terminal, then accidentally connected the positive cable to the negative terminal, what would happen? would it just blow a fuse before any serious damage would occur? and how would i check it to see if it's only a fuse????
Old Jun 23, 2004 | 07:30 PM
Motley's Avatar
Motley
it will spark like a mofo
Old Jun 23, 2004 | 07:31 PM
ODUB's Avatar
ODUB
Banned
but then what? would it just blow a fuse or would it damage something seriously?
Old Jun 23, 2004 | 07:33 PM
Motley's Avatar
Motley
you'll probably fry the battery, and blow fuses. ..and maybe from some wiring too.
Old Jun 23, 2004 | 07:35 PM
ODUB's Avatar
ODUB
Banned
the battery's okay....what wiring?
Old Jun 23, 2004 | 07:49 PM
Motley's Avatar
Motley
oh, ok, so instead of would if, ...it's more like I DID....
lol, anyways, check all your fuses...., check your wiring (under the dash), smell for any burnt wires. And if all is fine, and the battery is OK, then just test everything, lights, signals, brakes, etc..
good luck
Old Jun 23, 2004 | 07:52 PM
ODUB's Avatar
ODUB
Banned
this is what happened, the second it touched, the horn blew and it sparked...then when the connection was lifted, everything shut off
Old Jun 23, 2004 | 08:14 PM
Motley's Avatar
Motley
rotflmao..., sorry...
ah, so is everything OK?, or everything shut off?, no power?
Old Jun 23, 2004 | 09:20 PM
ODUB's Avatar
ODUB
Banned
no power
Old Jun 24, 2004 | 03:54 AM
vtecaccord01's Avatar
vtecaccord01
Performance isn't $$$
Damn, you connected it back and still no power, check your fuses and wires like they said. Hope this doesn't get to expensive. i thought batter cables where color coded so you don't do that?
