tires, speedo, etc
Old Jun 23, 2004 | 06:10 PM
wil4713's Avatar
wil4713
Default tires, speedo, etc
I went to buy new tires for my 5th gen accord with stock wheels the other day. the recommended tire size for the car is 195/60/15. i was in a bit of a hurry when i was buying them, and i bought tires that were the wrong size- 195/65/15's.
here are some questions:
i know that the '195' is the width of the tire, and that the '15' is the inside wheel size, and (is this right?) that the middle number refers to the ratio of the width of the tire tothe sidewall height. so, if i have a larger middle number, or a larger ratio, that means my sidewalls should be bigger than the 60's. does that mean my tires have a larger outside circumference than the recommended ones? like, would low-pro 16's be the same rolling size as "high-profile" 15's?
if my new tires are actually larger, i should have to recalibrate my speedometer/odometer, as i would be rolling on larger wheels and the measurements won't be accurate; does anyone know how to recalibrate them? or, if not, how much it might cost at a dealer?
thanks
Old Jun 24, 2004 | 05:39 AM
pablo13's Avatar
pablo13
Hi
Go to this site - you can type in the new tire size and it will tell you the difference in your speedo and circumference
http://www.miata.net/garage/tirecalc.html
I checked it for you and when your speedo shows 60mph - you will actually be going 61.9mph - also your circumference is 2.4in taller
If these tires aren't installed yet, I would go buy the proper size for them - a taller sidewall means your cornering won't be as good, and depending on your shocks' quality, you could bottom out when you have lots of passengers or a full trunk
As far as I know, you won't be able to recalibrate the speedo
Take it easy
Old Jun 24, 2004 | 10:09 AM
IamNemo's Avatar
IamNemo
You know me...
Originally Posted by pablo13
Hi
Take it easy
This guy's pretty much right. If you've already installed them, you shouldn't need to recalibrate...just remember that you're a couple of mph over and compensate for it. Get the right size next time...
Old Jun 24, 2004 | 05:16 PM
wil4713's Avatar
wil4713
thanks
Old Jun 26, 2004 | 03:35 PM
slade311's Avatar
slade311
milk-n-cookies
i take it ur still runnin stock rims...but personally i would exchange em if u could. there is a plus to having those bigger tires...ur odometer will register a mile after uve went further than a mile...this way u will be gettin more miles out of ur car without it saying so. its not really a big deal.
