Help me Obi Wan Kenobi
Old Jun 7, 2004 | 07:51 AM
Tobra's Avatar
Tobra
Default Help me Obi Wan Kenobi
One of my employees has a 1983 Accord, with about as many miles as you would expect. It has recently begun overheating. I am not familiar with these vehicles in particular and wonder if y'all would have any suggestions on what to investigate first. I have not looked at it at all.
Old Jun 7, 2004 | 07:52 AM
wedley2's Avatar
wedley2
bboy Wesley West
my dad says change radiator, and clean out lines and replace fluids, that will get that out of the way...
Old Jun 7, 2004 | 08:18 AM
jschmid's Avatar
jschmid
Check coolant levels, leaks, etc. See if and when fan is turning on. May be a bad thermostat.
Old Jun 7, 2004 | 08:19 AM
1992CivicSI's Avatar
1992CivicSI
Don't Conform, Innovate
Thermastat, fan, or leak. Check em.
Old Jun 7, 2004 | 08:22 AM
polakatl's Avatar
polakatl
my friend had to replace his water pump and radiator at 160k in a civic. It runs nice and cool now.
First I would top off the fluid. You can use distilled water for that. Once you have it full run the engine with the radiator cap off. Rev it up to a descent rpm and look inside the radiator. If the water is swooshing around or even spewing out then your pump is working. At that point I would say its an old radiator.
Does it overheat quickly or graduately?
Old Jun 7, 2004 | 08:30 AM
KAUAI KANE's Avatar
KAUAI KANE
91' Toyota Supra
From: Iwakuni, Japan. And where ever the Marine Corps sends me
do it in steps :
1. check for leaks (this means looking under neath as well)
2. if no leaks then flush the system till clean
3. if there is leaks fix em and still flush the system
if those steps do not remedy the problem then either three things went bad radiatior, thermostat, or water pump
4. i would suggest start with the thermostat if you replace that and still over heats go to next part radiator and then if that does not work go to the water pump
if you do have to replace any of these parts i would suggest replacing hoses at the same time (might as well
Old Jun 7, 2004 | 12:02 PM
Saxfiend's Avatar
Saxfiend
Resident Heckler
...You're my only hope.
^^^^What they said.
Old Jun 7, 2004 | 12:07 PM
KAUAI KANE's Avatar
KAUAI KANE
91' Toyota Supra
oh yeah i forgot the fan check that to but i doubt that broke .... and um the cars already old classic(20 years or older) should dump it and get a new one
Old Jun 7, 2004 | 12:08 PM
hondatech's Avatar
hondatech
Honda tech/eprom hackr
I wouldn't replace anything until you find out why it's overheating. Guessing isn't the way to fix anything. I would check the coolant, fluids. Run the car until it gets hot, when it starts to overheat check things like the fan, leaks, tstat opening (both hoses should be hot if open). Etc... I wouldn't go replacing rad, or flushing things out or whatever until you know what's causing a problem.
Old Jun 7, 2004 | 12:12 PM
wedley2's Avatar
wedley2
bboy Wesley West
werd on that one...
