car wont start
Old Jun 2, 2004 | 03:41 PM
94z's Avatar
94z
Default car wont start
awhile ago my 91 accord with 100xxx died while i was sitting at a traffic light. car had troubles starting then it barely ran. drove it back to my school shop couldnt get the car to go past 1500 rpm with it floored. had a lot more troubles starting it the next day having to floor it and hold the key for awhile and if i let off the gas it would die. next day car wont start at all and hasnt since then. the timing is correct on the cam. checked the distributor noticed the cap and rotor were bad replaced those. took out my distridutor replaced with another used distributor using my new cap and rotor. replaced the plugs. fuel pressure is 37 with vacuum connected. map sensor and coolant sensor are also fine. checked the wires for spark. checked all fuses. one was blown cooling fan however car had never overheated did replace the fuse. and by looking at the plugs it seems that it is running rich. tommorow i am going to check the iac any other ideas as to what the problem could be thanks Joe
Old Jun 2, 2004 | 07:27 PM
ak3883's Avatar
ak3883
Check your main relay(under dash, by steering wheel), if it won't start, would it ever not start when the car was really warm? Those main relays are notorious for failing in the 4th gen
Old Jun 2, 2004 | 08:20 PM
94z's Avatar
94z
i bought the car in just a little while ago. never had a problem with it starting before. however i live in MN and we really havent had any warm days were i drove it. is there any way to test the main relay. i had heard this from a friend that his went out as well but nether of us know a way to test it and i dont wanna start throwing parts at the car. thanks for the help Joe
Old Jun 3, 2004 | 12:38 PM
94z's Avatar
94z
how do i get to the main relay i foung were it should be in a diagram but cant get to it do i have to take the dash off to get to it? cleaned out the screen for the iac and tested the injectors all had 12v running threw em.
Old Jun 3, 2004 | 06:55 PM
ak3883's Avatar
ak3883
Google "main relay" +accord, that seemed to bring up loads of hits with this gen accords and the relay problems
Old Jun 3, 2004 | 07:34 PM
94z's Avatar
94z
after reading a page i found threw google it said that my accord would not have fuel pressure if the main relay went. i do have 37 psi with the vacuum connected so acording to that page my main relay would have to be good. so any other ideas anyone? thanks again Joe
Old Jun 4, 2004 | 09:38 AM
94z's Avatar
94z
we got the car runing again today it is only running on two cylinders however. it seems to be running extremely rich. the plugs are black when we pull them out but they are not wet. we took the bolts off the distributor and tried advancing it but it didnt run any different.
Old Jun 4, 2004 | 12:28 PM
ZiviCase10287's Avatar
ZiviCase10287
RacinMasonC
runs on cylinder #3 and #4... compression is 200-205 across each cylinder... pulled out plugs #1 and #2 and the firing didn't change at all... took out the plugs and tested for spark... there IS spark through the wires. maybe a 3 and 4 wires are bad but can still get spark?? can't get good connection on the spark plug??? help us out!
Mason
Old Jun 4, 2004 | 12:30 PM
ZiviCase10287
RacinMasonC
also about the fuel pressure.. it was 37 with vacuum on... thats ~47psi with it off.. that seems a little high, could the fuel pressure regulator be bad?
Old Jun 4, 2004 | 05:09 PM
94z's Avatar
94z
today we took downpipe off thinking the cat might be clogged. still had the same problem. then we took the tubing that goes from the pcv to intake manifold off. there was no vacuum but the air was coming out instead like the exhaust is all backed up. we are thinking that the egr valve may have failed and is blocking the airway so exhaust is going back up the intake. also on my ecu we checked the ground lines and to of them were bad. we just used conectors and made a new ground for the two wires right by the ecu. still not any better except now the car fires up a lot easier. then again the battery had been getting lower and we have had it on the charger so that might be part of it as well. anyone have any stories about when there egr went bad like how did it act??? i wont be able to work on the car again until monday thanks for any ideas
