Help me with this headlight!!!!
Old May 31, 2004 | 12:00 PM
thomasn's Avatar
thomasn
Default Help me with this headlight!!!!
I have for the last few months with my HEADLIGHTS . I've had them for about a year and they have started not working. It started off one headlight would blow then a couple of weeks later..... the other would blow. I figured it was because the wiring may have come loose. So I pulled off the bumper sure enough everything looks good. So I bought a couple of lights and replaced both, about a week later. They stopped working completely, except on high beam. so needless to say I work at night. I need help!!!
Old May 31, 2004 | 12:11 PM
did you check the fuse box? make sure you don't have any exposed wire too.
Old May 31, 2004 | 12:25 PM
Rice_Kit's Avatar
Rice_Kit
dyamn hahah had sammeeee problem with my friend...
But he took to dealer and they took care of that.. hmmm..
That's all I can say sorry man. But yea he took to dealer =) Good luck.
Hate when that happens.
Old May 31, 2004 | 12:58 PM
Nikon44's Avatar
Nikon44
Your friend took his car to the dealer and they fixed his *aftermarket* headlights? I wish my dealer would do that.
Anyways. Have you checked all your wire to make sure that you are not shorting out any where? Make sure your wires are protected. I have seen were a wire sleeving has rube away after a while on metal then started to short out.
Sean
Old Jun 1, 2004 | 11:29 AM
strykernyc's Avatar
strykernyc
sounds like the installation went wrong but then again u had them for a while without problem. i have same headlights just for a 96accord. check if the black wire is still good since u not supposed to cut it or touch it n anyway if that happens the results is ur problem. those headlight have 2 cables righ. one red one black. the red u can do whatever, black has to b ground well.
are u getting water in the bulbs? like from the inside under hood? u have the headlight cover from the inside?
i been having mines for a over a yr since they cameout first and never had a bulb burn out or anything bad. using h3 n the side h1 for headlights. g'luck
westcoaststyle
Do It Yourself
249
Feb 13, 2016 08:40 PM
slow95civic
92+ Civic/EL & Del Sol
5
Oct 3, 2003 05:17 PM
newbb
Accord
4
Sep 24, 2003 04:50 PM
ANGRYACCORD
Accord
4
Apr 17, 2003 12:16 PM
Accord1278
Accord
4
Jan 16, 2003 11:25 AM
