Not starting. Help ASAP.
Old May 4, 2004 | 08:20 PM
blueboy84's Avatar
blueboy84
Default Not starting. Help ASAP.
Hey, this afternoon i was cleaning the car and i disconnected the baterry to clean it also. The battery must have been out for about an hour. I put the battery back in, started the car fine, and drove and parked it on my street. A few hours later, i try to start the car and it dies out on my. There no power. The door lamps are still on. When i try to boost it from my dad's car, the battery cahrges and i can turn on the headlights and stuff, but then when i try to start the car... it just dies out on me. When i take the jumper cables off and put em back on, the charge comes back, but same thing.. it wont start. What can be the problem? im trying to get it started by tomorrow morning. Help please. I know disconnecting the battery for 15 mins resets the ECU, does this have anything to do with it?
Old May 4, 2004 | 08:35 PM
Bl@ck's Avatar
Bl@ck
Sinner
sounds like you got water somewhere under the hood that it's not supposed to go
Old May 4, 2004 | 09:58 PM
blueboy84's Avatar
blueboy84
it hasnt rained and i never washed the engine
Old May 5, 2004 | 08:18 AM
AccordCoup94's Avatar
AccordCoup94
distributor went out
Old May 5, 2004 | 08:50 AM
groovedaddy's Avatar
groovedaddy
Something similar happened to me. Turns out I left the map lights and dome light on which drained the battery in about an hour.
Old May 7, 2004 | 04:02 AM
syclone's Avatar
syclone
check to make sure your terminals are connected securely.. also check the main grounds, and alternator
Old May 7, 2004 | 06:15 AM
accordvtec77's Avatar
accordvtec77
could also be the alternator. If it's screwed, it won't charge the battery, and won't supply enough power to the vehicle's electrical system either.
Old May 7, 2004 | 12:31 PM
SmutWanter's Avatar
SmutWanter
"Made to Please"
Did the distributor or anything else electrical get wet?
Ineed2speed
Apr 8, 2004 06:15 PM
nosaccord2k
Feb 14, 2004 10:05 AM
peetee79
92+ Civic/EL & Del Sol
35
Feb 2, 2004 06:25 PM
zuczek
17
Oct 23, 2003 12:28 AM
