'97 Accord Door Adjustments
Old Apr 10, 2004 | 06:16 PM
Its Joje's Avatar
Its Joje
Default '97 Accord Door Adjustments
I need help on my 1997 Accord. The drivers side door doesn't close properly. It seems that it does not close far enough. If you look along the length of the car you can see how that door sticks out further than the rest. Also the switch that senses if that door is open isn't pushed in far enough to turn off the dome light or the door ajar warning. Does anyone know how to adjust the door or latch so that it closes properly? Thanks
Old Apr 10, 2004 | 11:45 PM
strykernyc's Avatar
strykernyc
thats a 123 fix i had the same problem when i got my car, just open the door and look n the corner of the door all u got to do is make sure the screw is tight and u fix. if u cant find it just let me know i can take pics but i am sure u will see it is very visible.
Old Apr 19, 2004 | 04:01 PM
Its Joje's Avatar
Its Joje
I looked in the corner and that switch is tightened down. it's not in the switch cause if I tape a dime over the spot where the door contacts the the switch it fools the car to think the door is closed all the way. I think the problem is that the door isn't closing far enough, like the latch is misaligned and doesn't close right.
Old Apr 20, 2004 | 08:58 AM
drummingaccord's Avatar
drummingaccord
same thing happened on my 95. Just took it to a body shop and they fixed the problem free of charge and in a few minutes. the door hasn't had a problem since, however it does periodically rattle.
maybe the repair guy left a screwdriver in there.
DJ Scotty
Accord
27
May 16, 2004 11:28 AM
AcuraFanatic
News & Rumors Archives
63
Aug 28, 2002 06:29 PM
