More power yaaa!!!!
Old Mar 19, 2004 | 06:44 AM
AccordinglyDone's Avatar
AccordinglyDone
Wicked Kustomz, CC
There are many ways to clean injectors. My class is going through this right now. Adidtives to your gas don't work I dont car how you did it, its like adding the little NOS bottle to your gas you arent any faster. Anyways heres what we did.
1. Unpluged the fuel pump. Harness in your truck passenger side just unplug the piggy back.
2. Unplug the fuel line to the fuel rail.
3. Next we used a guage tank, theres also different ways of doing this, one side has air compressor hook up to a guage then to a little tank that you pour the BEM fuel injector cleaner into then another valve with guage then a line to your fuel rail.
4. My cars fuel pressure with the regulator disconnected was 38 to 46 psi you want to run it at 35 no more no less so the system doesn't kick on.
5. turn the car on and let it run till it dies (fuel injector cleaner strong enough to run car and clean at the same time when car dies you know the tank is empty( not your gas tank))
6. At the same time you letting it run get the throttle body cleaner and spray directly into the intake manifold, if you spray to much at a time the car will bogg down but you do want to spray the whole bottle in.
7. After its all said and down the kit comes with a high potent gas aditives if it really works i dont know but its a lot bigger bottle than your buy at the gas station. Add that to a full tank of gas and your done.
Injectors cleaned and ready to go believe me that sh*t really works I got my kit from Poormans in my town for 27 dollars I believe you can get it at Autozone or wherever.
Old Mar 19, 2004 | 08:27 AM
strykernyc's Avatar
strykernyc
Did mines here professionaly done for $41 it smell so bad. i didnt notice any difference 70k
Old Mar 19, 2004 | 08:40 AM
AccordinglyDone
Wicked Kustomz, CC
alot of shops just empty a big container into the gas tank and drive it a bit. I felt a big difference but thats just my super duper fast 5th gen accord oh well till nest thread peace
Old Mar 19, 2004 | 10:45 PM
DIYguy's Avatar
DIYguy
NWH's DIYguy
1. ...just unplug the piggy back.
You mean that electrical plug in the trunk right?
3. Next we used a guage tank...
What's a Guage Tank?
huh? you have a picture of this?
Old Mar 21, 2004 | 01:11 PM
DIYguy's Avatar
DIYguy
NWH's DIYguy
hello?
Old Mar 22, 2004 | 06:26 AM
AccordinglyDone
Wicked Kustomz, CC
a guaged tank is and bottle or tank that you can dump fuel injections cleaner intothat has a top and bottom guage for psi and has an inlet and outlet air line.
Old Mar 22, 2004 | 10:51 AM
Intrepid241's Avatar
Intrepid241
um smart ass i know this but when i try helping out fellow HAN members. i'll post what i want when i want so dont be a butt about it because you didnt get to it first a-hole
Dude thats a bit of an overreaction. I was just playin...pop a prozac or something.
Old Mar 22, 2004 | 06:36 PM
RY2K's Avatar
RY2K
5 speed
Originally Posted by uclaccord
d'u need to do all that or can u just add the fuel injector cleaner additive to ur gas?
isn't injector cleaner bad for the O-rings
Old Mar 22, 2004 | 06:44 PM
big_eskimo's Avatar
big_eskimo
The reason those bottles of dump in don't work that well is because all they do is trap the gunk and grime it removes from the fuel system in the injector screens. If you have never seen one those things are sooooo small. If you really want to clean your fuel system you either have to remove the injectors and clean them after you flush the system or use an actual machine. The reason machines work so well is because they cycle cleaner in and out of the fuel system actually removing buildup.
jaje
News & Rumors Archives
8
May 7, 2003 09:54 AM
zeroGSR
Apr 23, 2003 10:29 PM
97 CIVIC EX
92+ Civic/EL & Del Sol
2
Mar 26, 2003 11:22 AM
epoxy
Prelude
2
Nov 1, 2002 04:09 PM
Nity4Accord
Accord
6
Jul 9, 2002 09:14 AM
