6th gen rear brake drum to disk conversion??
Old Feb 19, 2004 | 08:20 PM
polakatl's Avatar
polakatl
Default 6th gen rear brake drum to disk conversion??
I want to get discs in the back if the stopping power will be increased significantly. What I would like t know is if I get a steel brake line kit for the rear disc accords will that be enough to hook up the back brakes. I can look in a shop manual to find the necessary parts but I want to know if hooking it up will be a problem. Also what are good doner vehcles? Are the acuras any different in the brake department? TL-S maybe?
Also I'd like to improve the front stopping power. Any recommendations in this department are welcome.
I don't have ABS, will this be a problem?
Old Feb 19, 2004 | 11:13 PM
Wuzkrackin83's Avatar
Wuzkrackin83
i was looking around on the aem website and they have a rear brake conversion kit. it says for hondas then it says ideal for civic. wonder if they make one for the accords and how much it costs?
Old Feb 20, 2004 | 02:53 AM
Intrepid241's Avatar
Intrepid241
I'd Like to know too!
Old Feb 25, 2004 | 12:10 PM
polakatl's Avatar
polakatl
bump .... does the i4 ex have disks? Also is the front on v6 the same as i4? Will a brake line kit for 4 disk work with stock i4 front? and will it hook up to the rear lines leading to the brakes?
Old Feb 25, 2004 | 01:14 PM
Intrepid241
bump once more
Old Feb 25, 2004 | 02:18 PM
jschmid's Avatar
jschmid
All 6th gen EX's come with rear discs. The V6 fronts are bigger, but won't work unless you swap the whole spindles cause they are 5 lug.
You can swap out just the rear spindles with an I4 EX so you have discs, but don't expect braking to really improve. The ideal situation would be to get the rear spindles, lines, ebrake cable (which you'd need anyway) then also get the EX master cylinder, etc. But because you don't have ABS it won't be exactly like the EX brake system. I have no problem locking up my LX brakes lol...so I don't really see the need for greater braking force in the rear...sticker tires is really the only thing to decrease braking distance at full clamping force. More aggressive pads can help braking as long as you can modulate the pedal yourself. Braided lines give a firmer feel, and can reduce brake fade, but it's still up to modulating the brake pedal on LX's.
I don't blame you for wanting to swap though...I've thought about doing it too, just to get rid of the ugly drums out back. It's not so bad with stock wheels, but when you put lightweight 18's on there, it really shows off the ugly drums.
Old Feb 25, 2004 | 02:24 PM
polakatl's Avatar
polakatl
So I would need the rear e-brake cable? How about the other cables. Are they in the same position as the lx's. What I mean is if i get a steel line kit for rear disks will that cover the brake line needs? Is the master cylinder necessary or where u saying thats for abs?
I just don't see why my car doesn't like to stop like the new 03's do. The Nrakes don't look much larger if at all and abs can't be the reason since i'm not talking about mashing the pedal here. My dad keeps telling me its couse he has disks and I have drums, but I doubt thats entirelly true.
The ex front brakes are the same right? I would like to get a brembo 4 wheel brake kit since my front rotors could use a replacement.
Old Feb 25, 2004 | 02:38 PM
jschmid's Avatar
jschmid
Well I remember reading somewhere that the LX I4 was the fastest stopping of all the 6th gen Accords. This obviously was with good pedal modulation rather than just mashing it and locking them up. And again, this is just what i heard, but makes sense since it is lighter than the EX's, and as long as the driver is good a modulating the brake.
When you say Brembo's you just mean the OEM replacement blanks right? Cause those will work, cause you'll have EX spindles with calipers, just like putting them on an EX.
The EX ebrake cable is different near the rear discs, but the same near the ebrake handle. I don't know if the line has fittings in the middle so that you can still use part of the LX cable, and then swap out the second half to the EX, or if you need the whole thing.
Old Feb 27, 2004 | 01:28 AM
blurr
Guest
Posts: n/a
jschmid explained pretty much everything.. i'll just give a quick review of stainless steel brake lines.. it reduces fade under several hard braking such as road course racing.. other than that, it adds the benefit of a more direct brake feel.. you actually feel a larger range of modulation. the amount of pedal input will show in the amount of braking the car does..
Quick illustration:
Pedal input in a range of 1-10
1 2 3 4 5 6 7 8 9 10
What the braking system applies on stock lines:
1 2 2 3 3 4 7 7 8 8
with the stainless steel brake lines, you have better control of how much braking is applied and better feel.
Old Apr 17, 2020 | 05:16 PM
Shane Shamrock Kurshinsky's Avatar
Default bump sorry quick question
Can I use the wheel hubs from my lx with drums in a ex disc brake knuckle???
Tirod
Jun 25, 2003 01:53 PM
SilverLining
Accord
9
May 26, 2003 12:03 PM
acuracy
Mar 26, 2003 06:55 AM
acuracy
Mar 26, 2003 06:54 AM
brak
92+ Civic/EL & Del Sol
Mar 14, 2003 04:23 PM
